here is a working rule,
Thanks to accept solution :
Sub main
	Dim _inv As Inventor.Application = ThisApplication
	Dim PartDoc As PartDocument = ThisDoc.Document
	Dim oTG As TransientObjects = _inv.TransientObjects
	Dim oDocAssets As Assets = PartDoc.Assets
	Dim oAppearanceHighlightRed As Asset = GetOrCreateAsset(oDocAssets, "New HighlightRed")
	Dim ColorHighlightRed As ColorAssetValue = oAppearanceHighlightRed.Item("generic_diffuse")
	ColorHighlightRed.Value = oTG.CreateColor(255, 0, 0) ' red
	Dim oStartFace As Face
	Dim FaceList As New List(Of Face)
	While True
		oStartFace = _inv.CommandManager.Pick(Inventor.SelectionFilterEnum.kPartFaceFilter, "Fläche anwählen + ""Esc"" bestätigen.")
		' If nothing gets selected then we're done
		If oStartFace Is Nothing Then Exit While
		If FaceList.Count = 0 Then
			FaceList.Add(oStartFace) 'if crtl is pressed and listCount =0, we see crtl press as user fault, dont look
			oStartFace.Appearance = oAppearanceHighlightRed
		ElseIf Not FaceList.Contains(oStartFace) Then
			If Not System.Windows.Forms.Control.ModifierKeys = System.Windows.Forms.Keys.Control Then
			End If
		Else 'contains
			If System.Windows.Forms.Control.ModifierKeys = System.Windows.Forms.Keys.Control Then
				FaceList.Remove(oStartFace)
				oStartFace.AppearanceSourceType = AppearanceSourceTypeEnum.kBodyAppearance
			End If
		End If
	End While
	If FaceList.Count =0  Then Exit Sub
	'Area calculation
	Dim AreaCache As Double = 0
	For Each oFace As Face In FaceList
		AreaCache = AreaCache + oFace.Evaluator.Area
	Next
	If Not AreaCache = o Then
		AreaCache = Math.Round(AreaCache*100,1)
		MsgBox("Area : " & AreaCache & "mm²")
	End If
	'reset highligt
		oFace.AppearanceSourceType = AppearanceSourceTypeEnum.kBodyAppearance
		'other options to reset easy : kComponentOccurrenceAppearance,kDefaultAppearance,kFeatureAppearance,kMaterialAppearance,kPartAppearance
	Next
End Sub
Function GetOrCreateAsset(ByVal assets As Assets, ByVal assetName As String) As Asset
	Try
		Return assets.Item(assetName)
	Catch ex As Exception
		' Het asset bestaat nog niet, dus maken we er een aan
		Return assets.Add(AssetTypeEnum.kAssetTypeAppearance, "Generic", "HighlightRed", assetName)
	End Try
End Function
