A.Acheson
in reply to: Rich-T
Hi @Rich-T
I wasn't able to make my sample I had work mainly because I hadn't created any workplanes for the groove extrusion. In my case I used project geometry and constructed a sketch and use revolve.
Back to your scenario, trying to create a workplane in the part from the assembly environment was coming back with error not supported. The only way through with this method is to open the part itself and create the workplane in the part environment then close the part. This is very doable with the only snag being passing the selected face to the the workplane creation without the user needing to reselect as that would obviously be unproductive. I will give this a shot tomorrow and see what is possible.
Regards
Alan
