- Mute
- Permalink
- Report
Hello @robbeRtek,
I gave it a try and changed the code. The only problem is that not every overwrite is allowed to be reset to default. We also have colored areas that have to stay that way.
I tried to replace the highlight set with another collection in which the colors are stored. The part with the selection and deselection with CTRL works so far. However, inventor always stops when the areas are to be set to their original color while calculating the area. But that also seems to be a bug. If I display a message box beforehand, everything goes through as desired.
Edit: If I separate the calculation of the area and the recoloring and put the output of the calculation results in between, the problem is gone. However, this can only be implemented for individual parts and so the original problem remains because the highlight set would be the way to go for an assembly.
'Definition
Dim oApp As Inventor.Application = ThisApplication
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oCompDef As ComponentDefinition
oCompDef = oDoc.ComponentDefinition
Dim oStartFace,oFace As Inventor.Face '= Nothing
Dim AreaCache As Double = 0
Dim FaceCol As New Collection
FaceCol.Clear
Dim ColorCol As New Collection
ColorCol.Clear
Dim oHSet As HighlightSet = oDoc.CreateHighlightSet()
oHSet.Clear
' Definition der transienten Geometrie
Dim oTransObj As TransientObjects
oTransObj = oApp.TransientObjects
Dim docAsset As Assets
docAsset = oDoc.Assets
Dim oAssetLib As AssetLibrary
oAssetLib = oApp.AssetLibraries.Item("Autodesk Darstellungs-Bibliothek") 'Autodesk Appearance Library
Dim oColor As String
oColor = "Markierung"
' Get an asset In the library
Dim oHighlightColor As Asset
Try 'Copy the asset locally.
oHighlightColor = docAsset.Item(oColor)
Catch 'or just use it if it's already local
oHighlightColor = docAsset.Add(AssetTypeEnum.kAssetTypeAppearance, "Generic", oColor, oColor)
Dim generic_highlight_color As ColorAssetValue
generic_highlight_color = oHighlightColor.Item("generic_diffuse")
generic_highlight_color.Value = oHSet.Color
End Try
'wenn fertig, starte von vorn
TheStart:
While True
Dim k As Integer
k = 1
Dim bNEW As Boolean
bNEW = True
oStartFace = oApp.CommandManager.Pick(Inventor.SelectionFilterEnum.kPartFaceFilter, "Fläche anwählen + ""Esc"" bestätigen.")
' If nothing gets selected then we're done
If oStartFace Is Nothing Then Exit While
'wenn STRG gedrückt wird, sollen bereits selektierte Flächen wieder abgewählt werden
If System.Windows.Forms.Control.ModifierKeys = System.Windows.Forms.Keys.Control Then 'STRG wird gedrückt beim Selektieren
If FaceCol.Count>0 Then
For k = 1 To FaceCol.Count
oFace= FaceCol.Item(k)
If oFace.InternalName = oStartFace.InternalName Then
bNEW = False
Exit For
End If
Next
End If
If bNEW = False
FaceCol.Remove(k)
oFace.Appearance = ColorCol.Item(k)
ColorCol.Remove(k)
'oHSet.Remove(oFace)
oApp.ActiveView.Update
End If
Else 'STRG wird nicht gedrückt beim selektieren
bNEW = False
Exit For
End If
Next
End If
If bNEW = True Then
FaceCol.Add(oStartFace)
ColorCol.Add(oStartFace.Appearance)
oStartFace.Appearance = oHighlightColor
'oHSet.AddItem(oStartFace)
End If
End If
oStartFace = Nothing
End While
MessageBox.Show("random message")
'Berechenen der Flächeninhalte der Selektion
Dim i As Integer
If FaceCol.Count > 0 Then
For i = 1 To FaceCol.Count
oFace = FaceCol.Item(i)
AreaCache = AreaCache + oFace.Evaluator.Area
oFace.Appearance = ColorCol.Item(i)
Next
End If
If AreaCache = 0 Then Return
'Ausgabe Flächeninhalt
AreaCache = Math.Round(AreaCache*100,1)
MessageBox.Show(AreaCache & "mm²")
'oCompDef.ClearAppearanceOverrides() 'Alle farbig veränderten Flächen werden auf Standard gesetzt
oHSet.Clear
FaceCol.Clear
ColorCol.Clear
AreaCache = 0
'if done, go to the start
GoTo TheStart
