Hi kevin.hay,
I think you'd want to work with referenced files rather than occurrences. Here's a quick example.
Warning: run this on a small example file set, as it shows a message box for each referenced file name, which could mean dozens and dozens of clicks if you run this on a large assembly file, as is.
Also just as a tip,  programming questions of this type are better suited to search/ask on the Inventor Customization forum :
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oDoc As Document
Dim oRefFile As FileDescriptor
For Each oDoc In oAsmDoc.AllReferencedDocuments
	MessageBox.Show(oDoc.FullFileName, "iLogic")
	For Each oRefFile In oDoc.file.ReferencedFileDescriptors
		MessageBox.Show("This File: " & vbLf & oDoc.FullFileName _
		& vbLf & vbLf & "Refrences this file: " & vbLf & oRefFile.FullFileName, "iLogic")
	Next
Next
