11-03-2023
07:01 AM
- Mute
- Permalink
- Report
11-03-2023
07:01 AM
I have an iLogic rule to calculate the area of multiple selected faces.
The user should select all faces needed and after that press ESC and the calculation is done. When CTRL is pressed during the pick, already selected faces should get unselected. During that, all faces that are selected are highlighted.
The Problem is, if all selected faces get selected again, without pressing CTRL, the hightlightset is not highlightet anymore. The selectset and the highlightset are still containing all previous selected faces and the calculation of the area is working. Only the highlighting itself is not working.
I'm clueless, what might be the issue.
Thanks for your help .
'Definition
Dim oApp As Inventor.Application = ThisApplication
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oStartFace,oFace As Inventor.Face '= Nothing
Dim AreaCache As Double = 0
Dim FaceCol As New Collection
FaceCol.Clear
Dim oHSet As HighlightSet = oDoc.CreateHighlightSet()
oHSet.Clear
'if done, start again
TheStart:
On Error GoTo ENDE
While True
Dim i As Double
Dim k As Integer
k = 1
Dim bNEW As Boolean
bNEW = True
Dim oStartFaceIN, oFaceIN As String
oStartFace = ThisApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kPartFaceFilter, "Fläche anwählen + ""Esc"" bestätigen.")
' If nothing gets selected then we're done
If IsNothing(oStartFace) Then Exit While
''Läuft nicht
If System.Windows.Forms.Control.ModifierKeys = System.Windows.Forms.Keys.Control Then
If FaceCol.Count>0 Then
For i = 1 To FaceCol.Count
oFaceIN = FaceCol.Item(i).InternalName
oStartFaceIN = oStartFace.InternalName
If InStr(oFaceIN, oStartFaceIN) = 1 Then
bNEW = False
Exit For
End If
k = k + 1
Next i
End If
If bNEW = False
FaceCol.Remove(k)
oHSet.Remove(k)
ThisApplication.ActiveView.Update
End If
Else
bNEW = False
Exit For
End If
k = k + 1
Next i
End If
If bNEW = True Then
FaceCol.Add(oStartFace)
oHSet.AddItem(oStartFace)
End If
End If
''Läuft nicht
oStartFace = Nothing
End While
For Each oFace In FaceCol
AreaCache = AreaCache + oFace.Evaluator.Area
Next
If AreaCache = 0 Then
GoTo ENDE
End If
AreaCache = Math.Round(AreaCache*100,1)
MessageBox.Show(AreaCache & "mm²")
oHSet.Clear
FaceCol.Clear
AreaCache = 0
'if done, go to the start
GoTo TheStart
Return
ENDE:
