bradeneuropeArthur
141 Views, 0 Replies
Model State Master Primary Lock
Because I think the "Model State" Master Primary  should be Locked for edit (in some cases) I have created an add in to prevent edit this specific "Model State".
Watch this movie for explanation:
Link to the related topic;
https://forums.autodesk.com/t5/inventor-forum/is-master-model-state-no-longer-an-actual-master/td-p/...
Also I have created a Idea in the Idea Station:
https://forums.autodesk.com/t5/inventor-ideas/lock-the-quot-master-primary-quot-model-state/idi-p/12...
Arthur Knoors
Autodesk Affiliations:
