C_Haines_ENG
382 Views, 6 Replies
Turn off Sketch Symbol Leader
Im looking for a way to toggle all sketch symbols leaders off. I have the code below to attempt this but the .Leader property is read only.
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
Dim oSketchedSymbols As SketchedSymbols = oSheet.SketchedSymbols
For Each oItem As SketchedSymbol In oSketchedSymbols
oItem.LeaderVisible = False
oItem.Leader 'THIS IS READ ONLY???
Next
 Does anyone else know how to solve this?
Labels (4)
mfoster9TD82
in reply to: C_Haines_ENG
You may need to get the placement and sketch symbol definition from the existing sketch symbol, delete it and place another one using SketchedSymbols.Add(). It doesn't really looks like you can remove leaders from sketch symbols, but you can add them...
Edit:
I was mistaken. After fooling around with it more, you can delete the all the Nodes in the leader of each sketch symbol:
	If Not oItem.Leader Is Nothing AndAlso Not oItem.Leader.AllNodes Is Nothing Then
		While Not oItem.Leader.AllNodes Is Nothing AndAlso oItem.Leader.AllNodes.Count > 0
			oItem.Leader.AllNodes(1).Delete
		End While
	End If
Next
edit2: code fix
C_Haines_ENG
in reply to: mfoster9TD82
Inventor doesnt seem to like this line:
Class not registered, incorrect parameter, etc.
mfoster9TD82
What version of inventor are you using?
And are you getting that in a compiler error or a runtime error?
Dim d As DrawingDocument = ThisDrawing.Document
Dim s As Sheet = d.ActiveSheet
Dim sss As SketchedSymbols = s.SketchedSymbols
	For Each ss As SketchedSymbol In sss
	Try
		ss.Leader.AllLeafNodes.Item(1).Delete
Catch
	End Try
Next
Arthur Knoors
Autodesk Affiliations:
A.Acheson
Hi @C_Haines_ENG
Is your goal to switch off the leader visibility
You might want to put in an error trap for any that are off also. If you go about deleting then you have nothing to bind the symbol to the view.
Syntax
SketchedSymbol.LeaderVisible() As Boolean
Property Value
This is a read/write property whose value is a Boolean.
Regards
Alan
Looks like the try line saved it from bugging out, thank you.
