10-30-2023
09:17 PM
- Mute
- Permalink
- Report
10-30-2023
09:17 PM
@A.Acheson Thank you for Solution, yes, I've updated my code to References document, and now it's only placed base view of unique parts only, could you please help me more on that as I described earlier, I'm interested to place view, so it'll not overlap as well control scale based on Sheet size.
Please find my updated code below :
Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument Dim oDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition Dim oOcc As ComponentOccurrence Dim oTPath As String = "C:\Users\Public\Documents\Autodesk\Inventor 2023\Templates\en-US" Dim oTName As String = "Standard.idw" Dim oTFullFileName As String = System.IO.Path.Combine(oTPath, oTName) Dim oDDoc As DrawingDocument = Nothing If System.IO.File.Exists(oTFullFileName) Then oDDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, oTFullFileName, True) Else MsgBox("Template Drawing could not be found!", vbCritical, "") Exit Sub End If Dim oTG As TransientGeometry = ThisApplication.TransientGeometry Dim oViews As DrawingViews = oDDoc.ActiveSheet.DrawingViews Dim oFullScale As Double = 1/5 Dim oOriginPoint As Point2d = oTG.CreatePoint2d(0, 0) Dim oRefDocs As DocumentsEnumerator oRefDocs = oAsmDoc.AllReferencedDocuments ' Iterate through the list of documents. Dim oRefDoc As Document For Each oRefDoc In oRefDocs Dim oBaseView As DrawingView = oViews.AddBaseView(oRefDoc, oOriginPoint, oFullScale, _ kBottomViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle) Next
