10-30-2023
01:50 AM
- Mute
- Permalink
- Report
10-30-2023
01:50 AM
Hello all, my aim to place base view of all parts of assembly, I've tried below code and it's working okay to add parts base new, now i need to find out which parts are repetitively used in assembly and not need to add base view of same parts. And I also need to adjust scale and postion of view based on Sheet size.
Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument Dim oDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition Dim oOcc As ComponentOccurrence Dim oTPath As String = "C:\Users\Public\Documents\Autodesk\Inventor 2023\Templates\en-US" Dim oTName As String = "Standard.idw" Dim oTFullFileName As String = System.IO.Path.Combine(oTPath, oTName) Dim oDDoc As DrawingDocument = Nothing If System.IO.File.Exists(oTFullFileName) Then oDDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, oTFullFileName, True) Else MsgBox("Template Drawing could not be found!", vbCritical, "") Exit Sub End If Dim oTG As TransientGeometry = ThisApplication.TransientGeometry Dim oViews As DrawingViews = oDDoc.ActiveSheet.DrawingViews Dim oFullScale As Double = 1/5 Dim oOriginPoint As Point2d = oTG.CreatePoint2d(0, 0) For Each oOcc In oDef.Occurrences Dim oOccDoc As Document = oOcc.Definition.Document Dim oBaseView As DrawingView = oViews.AddBaseView(oOccDoc, oOriginPoint, oFullScale, _ kBottomViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle) Next
