vdcrocks7
225 Views, 3 Replies
Add Base view of independent parts of assembly in single new drawing.
Hello all, my aim to place base view of all parts of assembly, I've tried below code and it's working okay to add parts base new, now i need to find out which parts are repetitively used in assembly and not need to add base view of same parts. And I also need to adjust scale and postion of view based on Sheet size.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
	Dim oTPath As String = "C:\Users\Public\Documents\Autodesk\Inventor 2023\Templates\en-US"
	Dim oTName As String = "Standard.idw"
	Dim oTFullFileName As String = System.IO.Path.Combine(oTPath, oTName)
	Dim oDDoc As DrawingDocument = Nothing
	If System.IO.File.Exists(oTFullFileName) Then
		oDDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, oTFullFileName, True)
	Else
		MsgBox("Template Drawing could not be found!", vbCritical, "")
		Exit Sub
	End If
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim oViews As DrawingViews = oDDoc.ActiveSheet.DrawingViews
	Dim oFullScale As Double = 1/5
	Dim oOriginPoint As Point2d = oTG.CreatePoint2d(0, 0)
	For Each oOcc In oDef.Occurrences
		Dim oOccDoc As Document = oOcc.Definition.Document
			Dim oBaseView As DrawingView = oViews.AddBaseView(oOccDoc, oOriginPoint, oFullScale, _
		kBottomViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
	Next
Tags (1)
A.Acheson
in reply to: vdcrocks7
Hi @vdcrocks7
For this you can use referenced documents instead of occurrences. Referenced document is the document all of the same occurrence reference so their is only one. See article here on working with assemblies and look for paragraph Reference Documents.
Sub Main
    ShowReferences()
End Sub
Public Sub ShowReferences()
    ' Get the active assembly.
    ' Get all of the referenced documents.
    Dim oRefDocs As DocumentsEnumerator
     oRefDocs = oAsmDoc.AllReferencedDocuments
    ' Iterate through the list of documents.
    Dim oRefDoc As Document
    For Each oRefDoc In oRefDocs
      Logger.Info(oRefDoc.DisplayName)
    Next
End Sub
Regards
Alan
vdcrocks7
@A.Acheson Thank you for Solution, yes, I've updated my code to References document, and now it's only placed base view of unique parts only, could you please help me more on that as I described earlier, I'm interested to place view, so it'll not overlap as well control scale based on Sheet size.
 Please find my updated code below :
	Else
		Exit Sub
	End If
			Dim oBaseView As DrawingView = oViews.AddBaseView(oRefDoc, oOriginPoint, oFullScale, _
		Next
A.Acheson
Hi @vdcrocks7
Those two topics are very difficult so you will need to do your research on them. Depending on your view layout complexity the view scale can be achieved by just checking the view height x width of each view and adjust the scale untill it comes inside the sheet rangebox. Regarding overlapping really the easiest method is to check height x width of each view against its location and determine if they are overlapping. I have seen a few post getting overlapping drawing curves but that definitely isn't for the beginner.
A quick internet search using kewords
"ilogic autoscale drawing view"
1. View scale
2. View scale and position
Regards
Alan
