10-26-2023
08:17 AM
- Mute
- Permalink
- Report
10-26-2023
08:17 AM
Hi @blandb. I have not really looked into it yet, but if it will not allow you to specify an empty String as its name when you originally create it by code, then maybe it will allow you to supply a random or unique name when creating it, then change its name to an empty String afterwards. If the pattern has a BrowserNode, then we should be able to set its name to an empty string after the fact, to reset its name to its default, with the next index Integer after its name. Just a quick thought.
Wesley Crihfield
(Not an Autodesk Employee)
