FINET_Laurent
226 Views, 3 Replies
Programmatically make the difference between Inventor & AutoCad .dwg
Hi folks,
I have a list of .dwg files. I would like to remove the AutoCad .dwgs & keep the Inventor .dwg.
How can I make the difference between the two programmatically ?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
