- Mute
- Permalink
- Report
Hi @CCarreiras. While working on something else, another thought about this case came to mind. Maybe try renaming each of the sheets in the original drawing to unique names (before the ":1" portion) before the export process. The ":1" portion is added and managed automatically by Inventor, so we can not change that. If you change the order of the sheets, those trailing Index numbers will not move with the sheets, they will stay in order (top sheet's name will end with ":1" no matter what). And since the default base name "Sheet" is the same for every sheet, that is most likely messing with the process of copying that sheet to the other temp drawing, because if it was "Sheet:3" in the original document, it will always be "Sheet:1" in the temp drawing. Since each resulting DXF file is expected to be named like the sheet, it would then be trying to export to the same file each time. I am just guessing that if the portion of each sheets name, before the ":" symbol was unique, that may help the process succeed. Just a thought at this point though. Still busy on a project at work.
Wesley Crihfield
(Not an Autodesk Employee)
