WCrihfield
in reply to: Michael.Navara
Hi @Michael.Navara.  I saw the rule within the attached part, where you are utilizing a Windows Form.  Not a bad idea.  Something I have seen, but have not really explored that much yet myself, is the FactoryTableDialog object that we can create through the Inventor application.  That may also be something worth looking into also in this case.  It says that it is for iPart / iAssembly type use, but since the ModelStateTable is laid out pretty much identically, and uses some of the same controls & terms, I am curious to test if it might work with a ModelStates document also.  Just throwing that idea out there.
Wesley Crihfield
(Not an Autodesk Employee)
