10-23-2023
12:07 PM
- Mute
- Permalink
- Report
10-23-2023
12:07 PM
HI Wesley,
Thanks for this, i am having a little trouble integrating this into the other code.
I am also wondering if there is a way to have the pop up you had written start at a specific location.
For example, have it pop up already in
G:\Dropbox\PROJECTS WIP
I have written the code below that i have been using below
Sub Main()
Dim myDate As String = Now().ToString("yyyy-MM-dd HHmmss")
myDate = myDate.Replace(":","") ' & " - " & TypeString
userChoice = InputRadioBox("Defined the scope", "This Document", "All Open Documents", True, Title := "Defined the scope")
UserSelectedActionList = New String(){"DXF & PDF", "PDF Only", "DXF Only"}
UserSelectedAction = InputListBox("What action must be performed with selected views?", _
UserSelectedActionList, UserSelectedActionList(0), Title := "Action to Perform", ListName := "Options")
Select UserSelectedAction
Case "DXF & PDF": UserSelectedAction = 3
Case "PDF Only": UserSelectedAction = 1
Case "DXF Only": UserSelectedAction = 2
End Select
If userChoice Then
Call MakePDFFromDoc(ThisApplication.ActiveDocument, myDate, UserSelectedAction)
Else
For Each oDoc In ThisApplication.Documents
If oDoc.DocumentType = kDrawingDocumentObject
Try
If Len(oDoc.File.FullFileName)>0 Then
Call MakePDFFromDoc(oDoc, myDate, UserSelectedAction)
End If
Catch
End Try
End If
Next
End If
End Sub
Sub MakePDFFromDoc(ByRef oDocument As Document, DateString As String, UserSelectedAction As Integer)
' oPath = oDocument.Path
' oFileName = oDocument.FileName(False) 'without extension
'oDocument = ThisApplication.ActiveDocument
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oFullFileName = oDocument.File.FullFileName
oPath = Left(oFullFileName, InStrRev(oFullFileName, "\")-1)
oFileName = Right(oFullFileName, Len(oFullFileName)-InStrRev(oFullFileName, "\"))
oFilePart = Left(oFileName, InStrRev(oFileName, ".")-1)
'oRevNum = oDocument.iProperties.Value("Project", "Revision Number")
' If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
' End If
'get PDF target folder path
'oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
oFolder = oPath & "\iLogic PDF's (" & DateString & ")"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFilePart & ".pdf"
'Publish document
If (UserSelectedAction = 1) Or (UserSelectedAction = 3) Then
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)'For PDF's
End If
If (UserSelectedAction = 2) Or (UserSelectedAction = 3) Then
oDocument.SaveAs(oFolder & "\" & oFilePart & ".dxf", True) 'For DXF's
End If
'oDocument.SaveAs(oFolder & "\" & ThisDoc.ChangeExtension(".dxf"), True) 'For DXF's
'------end of iLogic-------
End Sub
