10-23-2023
07:13 AM
- Mute
- Permalink
- Report
10-23-2023
07:13 AM
I did a quick test and was able to get this to work with Inventor 2023. See steps below, just in case this is a workflow issue ( I had to refresh my memory on how this all worked) .
Just to confirm the workflow:
- I created a run with a fitting in a T&P assembly.
- I used the Save and Replace to create a copy in a read/write location
- Assemble tab > Productivity panel > Save and Replace
- This resulted in 2 fittings
- I opened this new copy fitting part file by itself
- Ran the Macro
- Returned to the assembly and right clicked on it in the browser and confirmed the T&P options were no longer there
- Right clicked on the original fitting in the browser and confirmed the T&P options were still there
I hope this helps.
Curtis
