robertast
in reply to: ppolcynBNVFN
This code is for the part more interesting. The Part List comes with both number part and quantity.
Sub Main
Dim invDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = invDoc.ActiveSheet
Dim oSheet1 As Sheet = invDoc.Sheets.Item(1)
Dim oDrawingView As DrawingView = oSheet1.DrawingViews(1)
Dim oBorder As Border = oSheet.Border
Dim oPlacementPoint As Point2d
If Not oBorder Is Nothing Then
oPlacementPoint = oBorder.RangeBox.MaxPoint
Else
oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width, oSheet.Height) 'Kur ideti partlista
End If
Dim partsListBomType As PartsListLevelEnum = 46593
Dim oPartsList_G As PartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint, partsListBomType)
For Each oRow In oPartsList_G.PartsListRows
	oRow.Visible = True
Next
Dim oView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "pick drawing view.")
Dim oSheet2 As Sheet = oView.Parent
Dim RefDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
        Dim RefDocName As String = RefDoc.FullFileName
 Dim oPartList As PartsList = oPartsList_G
Dim PLRows As PartsListRows = oPartList.PartsListRows
For Each PLRow As PartsListRow In PLRows
   Dim ListDoc As Document = PLRow.ReferencedRows.Item(1).BOMRow.ComponentDefinitions.Item(1).Document()
   If Not ListDoc.FullFileName = RefDocName Then
      PLRow.Visible = False
   End If
Next
ThisApplication.CommandManager.ControlDefinitions.Item("DrawingUpdateAllSheetsCmd").Execute
End Sub
If for example, @A.Acheson   or @JelteDeJong  I adjusted it so that it reacts to both Subassembly and Assembly, it would be generally ideal.
