Daan_M
182 Views, 2 Replies
Replacing specific characters of a string
I have a string variable in format: [Name]_xxx_[Something else]
And another string variable called size : "999"
I want to replace the "xxx" with the size variable, but i can't get it to work.
I tried the following:
Dim oVar2 As String = GoExcel.CellValue(oExcel, "Blad1", "D" & oSubCellCount)
'Gives output: "EUA_xxx_A"
Dim oVarSize As String 	= GoExcel.CellValue(oExcel, "Blad1", "B" & oCellCount)
'Gives output: "025"
Replace(oVar2, "xxx", oVarSize)
Msgbox(oVar2)
'Still gives output "EUA_xxx_A" and not the desired "EUA_025_A"
i also tried without succes:
oVar2.replace("xxx", oVarSize)
The solution is probabably pretty simple, but an explanation of what i do wrong is appreciated.
Daan_M
in reply to: Daan_M
Found it, i needed to assign the change to the string variable itself:
oVar2 = replace(oVar2, "xxx", oVarSize)
m_baczewski
in reply to: Daan_M
Hi @Daan_M
You should assign a variable in my case its newString, but you can assign oVar1 as newString
oVar1 = "EUA_xxx_A"
oVarSize = "025"
newString = Replace(oVar1, "xxx", oVarSize)
Logger.Info(newString)
