10-18-2023
12:30 PM
- Mute
- Permalink
- Report
10-18-2023
12:30 PM
Class Not Registered Error
I keep receiving a "Class Not Registered" error every time I try to run this code. I have searched around the forums, but have not been able to find any solutions.
' Initialize Inventor application
Dim inventorApp As Inventor.Application
inventorApp = ThisApplication
' Check if an assembly document is active
If inventorApp.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MsgBox("Please open an assembly document first.")
Exit Sub
End If
' Get the active assembly document
Dim originalAssembly As AssemblyDocument
originalAssembly = inventorApp.ActiveDocument
' Prompt the user for a new file name for the copied assembly
Dim newFileName As String
newFileName = InputBox("Enter a new file name for the copied assembly:", "Copy Assembly")
' Check if the user canceled the input
If newFileName = "" Then
Exit Sub
End If
' List of components to be reused (replace with your own file names)
Dim componentsToReuse As New List(Of String)
componentsToReuse.Add("UHDL13.50CollarPhantom.iam")
componentsToReuse.Add("907926.ipt")
' Save a copy of the assembly with the new file name
originalAssembly.SaveAs(newFileName, True)
' Close the original assembly
originalAssembly.Close(True)
' Open the copied assembly
Dim copiedAssembly As AssemblyDocument
copiedAssembly = inventorApp.Documents.Open(newFileName)
' Iterate through the components in the copied assembly and remove suppressed components
For Each component As ComponentOccurrence In copiedAssembly.ComponentDefinition.Occurrences
If Component.Suppressed Then
Component.Delete2(True) ' Delete the suppressed component
End If
Next
Dim componentName As String
componentName = Component.Name
' Check if the component should be reused or copied
If componentsToReuse.Contains(componentName) Then
' Component should be reused
' You can add code here to update the position or configuration if needed
Else
' Component should be copied
' You can add code here to copy the component or replace it with a new version
' For example, you can replace it with a different IPT file using the File.Copy function.
End If
Next
' Inform the user
MsgBox("Assembly copied successfully with a new file name: " & newFileName)in line 30
