A.Acheson
in reply to: ppolcynBNVFN
Hi @ppolcynBNVFN
When you add a partlist and intend it to be for an assembly you need to set the PartlistlevelEnum which is parts only or structured all level etc. See partlist.add method API help here.
If you look at the more info tab of the error message this might be explained. Tab 1 is no good for diagnostics and should be ignored.
In the API help page navigate to PartsListLevelEnum here and select the correct one.
Syntax
PartsLists.AddViewOrModel As Object, PlacementPoint As Point2d, [Level] As PartsListLevelEnum, [NumberingScheme] As Variant, [NumberOfSections] As Long, [WrapLeft] As Boolean ) As PartsList
Regards
Alan
