ppolcynBNVFN
in reply to: JelteDeJong
I had only tested this on drawing sheets with parts, and it works fine, but when trying it on a sheet with an assembly I get the following error(below). If I place a parts list manually, it will set it to the correct format. It is just unable to place it by itself.
