Daan_M
168 Views, 2 Replies
Placing components with iMates, multiple positions
I'm trying to figure out a way to place components with multiple iMates with iLogic.
Right now i place the torque arm on the gearbox with a simple insert iMate defined within the partfiles using the following code in my assembly;
oACD.Occurrences.AddUsingiMates()
This works fine:
The problem is that the torque arm can also be assembled on the other side of the gearbox:
Is there any solution that allows me to define the placement side in iLogic?
For example maybe its possible I put 2 iMates in both the torque arm and gearbox parts (Left and Right side), and then i choose which one should be used in iLogic?
A.Acheson
in reply to: Daan_M
Hi @Daan_M
If you look at this vba sample it will likely have what your looking for. You will need to look through your gearbox occurrence and find and select what definition you want to use. Knowing which index number might be enough for you.
Regards
Alan
m_baczewski
in reply to: Daan_M
Yes, it's possible. You need to define the type and alignment of the iMate on the gearbox and the torque arm and update those constraints as needed:
Dim componentA = Components.Add("CZ11", "Your\Path\CZ11.ipt")
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim constrains As AssemblyConstraints
constrains = oDoc.ComponentDefinition.Constraints
For Each constrain In constrains
	constrain.Delete
Next
Select Case SIDE
Case = "LEFT"
	Constraints.AddByiMates("Left1", "CZ10", "W1", "CZ11", "W1")
	Constraints.AddByiMates("Left2", "CZ10", "W2", "CZ11", "W2")
Case = "RIGHT"
	Constraints.AddByiMates("Right1", "CZ10", "W3", "CZ11", "W3")
	Constraints.AddByiMates("Right2", "CZ10", "W4", "CZ11", "W4")
End Select
m_baczewski_0-1697784600630.pngm_baczewski_1-1697784605701.pngm_baczewski_2-1697784609372.png
