maxim.teleguz
in reply to: cmcconnell
found a beautiful way of doing this, you are welcome world.
	Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim oSheet As Sheet
	Dim oRevTable As RevisionTable = oDrawDoc.ActiveSheet.RevisionTables.Item(1)
	Dim oRows As RevisionTableRows = oRevTable.RevisionTableRows
	Dim oApp As Inventor.Application = ThisApplication
	Dim UNDO As Transaction = oApp.TransactionManager.StartGlobalTransaction(oDrawDoc, "Remove Static from Revision Table")
	P = iProperties.Value("Project", "Revision Number")
	oRows.Add()
	Dim oRow As RevisionTableRow = oRevTable.RevisionTableRows.Item(oRevTable.RevisionTableRows.Count)
	For Each oRow In oRows
		If oRow.IsActiveRow Then
		Else
			oRow.Delete
		End If
	Next
	Dim oCell1 As RevisionTableCell = oRevTable.RevisionTableRows.Item(1).Item(1)
	Dim sFText As String = oCell1.FormattedText
	sFText = P'InputBox("What is the Revision?", "RevisionTableCell.FormattedText", P)
	oCell1.FormattedText = sFText
	c = "REV"
	'just in case it doenst exit recreate it
	Try : x = iProperties.Value("Custom", c) : Catch : iProperties.Value("Custom", c) = "Job number/Reason Code or ECN #" : End Try
	iProperties.Value("Custom", c) = sFText
	iProperties.Value("Project", "Revision Number") = sFText
UNDO.End
