A.Acheson
in reply to: ppolcynBNVFN
Hi @ppolcynBNVFN
The easiest method is using the ilogic API route. This targets the document at view (1) of sheet (1)
Dim modelDoc As Document = ThisDoc.ModelDocument
The longer method is the Inventor API route helpful article here
Then once you have the document you can determine its document type see help page here
Syntax
Document.DocumentType() As DocumentTypeEnum
Property
If doc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
'DO SOMETHING
End If
Regards
Alan
