A.Acheson
in reply to: mbreed5XTGY
Hi @mbreed5XTGY
If the assembly is in the drawing then you can access the BOM or Document references of the assembly then produce a list. Once you get that far then you need to check if you have a drawing at that filepath, open and copy sheet etc.
ModelDocument ilogic API help page
All Referenced Documents Inventor Api Help Page
Dim partsList as New List (Of String)
Dim modelDoc As AssemblyDocument = ThisDoc.ModelDocument
For Each doc As Document In modelDoc.AllReferencedDocuments
   If doc.DocumentType = DocumentTypeEnum.kPartDocumentObject _ 'Part
   AndAlso doc.IsModifiable  Then 'Not read only CC/Library document
    partsList.add(Doc.FullFileName)
   End If
Next
d0 = InputListBox("Prompt", partsList, d0, Title := "Title", ListName := "List")
Regards
Alan
