GosponZ
in reply to: jsternamanLULAE
Here is one more for pink dimensions
'This code deletes unattached dimensions
    ' Set a reference to the active drawing document
    Dim oDoc As DrawingDocument
    oDoc = ThisDoc.Document 'ThisServer.ActiveDocument
    ' Set a reference to the active sheet
'    Dim oSheet As Sheet
    oSheet = oDoc.ActiveSheet
    ' Iterate over all dimensions in the drawing
    ' and delete unattached (sick) dimensions.
    For Each oDrawingDim In oSheet.DrawingDimensions
        If oDrawingDim.Attached = False Then
            Call oDrawingDim.Delete
        End If
		Next
