jsternamanLULAE
526 Views, 6 Replies
Rule doesn't work for removing extra dimensions
How do I remove the unwanted dimensions after I shorten my piece on the drawing?  When I shorten the part and holes go aways but the dimensions stay and turn magenta.  How do I remove the dimensions.  The code I have does not work.  It works from my local files but not from vault.
This is the error I get when I open drawing from vault...
This is the code that I found that should but does not work...
This the view before....
This is after and want the dimensions removed before drawing is saved.
