09-28-2023
07:43 AM
- Mute
- Permalink
- Report
09-28-2023
07:43 AM
Found the problem, for future people, this code lets you:
- Select a windows folder
- It will find all .ipt files in it
- Mirror all the .ipt files, regardless if they are a single or multibody part
- Save the .ipt files as COPY into a new folder called "Output"
- Dont forget to set your own part template file location in the code
Imports System.Windows.Forms
Imports System
Sub Main
oInvApp = ThisApplication
Dim oTemplate As String = '.IPT TEMPLATE FILE e.g. "X\Templates\Partemplate.ipt"
Dim oFBD = New FolderBrowserDialog()
oFBD.ShowDialog()
Dim oSFolder = oFBD.SelectedPath
If String.IsNullOrEmpty(oSFolder) Then Exit Sub
Dim oFiles() As String = IO.Directory.GetFiles(oSFolder, "*.ipt")
If oFiles.Length = 0 Then Exit Sub
Dim i As Integer = 0
For Each oFile In oFiles
Dim oFileName As String = IO.Path.GetFileName(oFiles(i))
Dim oFileNameWE As String = IO.Path.GetFileNameWithoutExtension(oFiles(i))
Call MirDer(oFiles(i), oFileNameWE, oSFolder)
i = i + 1
Next
End Sub
Dim oInvApp = ThisApplication
Private Function MirDer(ByVal oFileName As String, ByVal oFileNameWE As String, ByVal oSFolder As String)
Dim CopyDoc As PartDocument = oInvApp.Documents.Add(kPartDocumentObject, oTemplate, False)
Dim oPCD As Inventor.PartComponentDefinition = CopyDoc.ComponentDefinition
Dim oDPD As Inventor.DerivedPartDefinition
oDPD = oPCD.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(oFileName)
oDPD.IncludeAllSolids = DerivedComponentOptionEnum.kDerivedIncludeAll
oDPD.MirrorPlane = kDerivedPartMirrorPlaneXY
Dim oDPC As DerivedPartComponent = oPCD.ReferenceComponents.DerivedPartComponents.Add(oDPD)
oDPC.BreakLinkToFile()
CopyDoc.Update()
Dim OutputFolder As IO.DirectoryInfo = IO.Directory.CreateDirectory(oSFolder & "\Output")
CopyDoc.SaveAs(OutputFolder.FullName & "\" & oFileNameWE & "_MIRROR_.ipt", False)
CopyDoc.Close(True)
End Function
