FINET_Laurent
in reply to: Daan_M
@Daan_M,
Maybe I went too quick in my previous post. You might still need to add the command to add all the bodies in the part, since the default option may change with Inventor settings (I might be wrong here).
Can you maybe test out the code on a single part instead, with just the document creation & the derive function to see the output? Maybe it is missing a doc.Save or a doc.Update
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
