dustinbagley
in reply to: WCrihfield
@WCrihfield No worries, I'm glad you made that other post because it will simplify my code a bit more with the switch extension function. I was not aware of that and as you can see below, I was working a lot harder than I was needing to. Thank for your help.
'[Gets drawing file name from assembly/part filename
FullFileName = oAssyDoc.FullFileName
'strips path
FileName = Right(FullFileName, Len(FullFileName) -InStrRev(FullFileName, "\"))
'strips extension
Name = Left(FileName, Len(FileName) -4)
'adds drawing path and extension
DrawingFileName = DrawingPath & Name & ".idw"
