WCrihfield
in reply to: dustinbagley
Hi @dustinbagley.  This is an odd question.  Files and documents are two different things.  A file is what gets saved to a hard drive, with a file address.  A document is basically just a reference to the organized data being held in Inventor's session memory, which may have been at least partially read from a file, or created within the software, and has not been saved as a File to the hard drive yet.  A Document object has a ReadOnly property named File, which will return Inventor's version of a File object.  That Inventor File object then has a Read/Write property named FullFileName, where you can only 'set' its value when that File has not been saved yet.  Once the Document/File has been saved, that either creates or updates the File on the hard drive, but leaves the Document open in Inventor's session memory, until you Close it.
Wesley Crihfield
(Not an Autodesk Employee)
