JelteDeJong
in reply to: negutorthik
try this:
Dim extension = ".csv"
Try
    If (System.IO.File.Exists(ThisDoc.PathAndFileName(False) + extension)) Then
        System.IO.File.Delete(ThisDoc.PathAndFileName(False) + extension)
    End If
    Dim sBom = ThisDoc.Document.ComponentDefinition.BOM
    sBom.PartsOnlyViewEnabled = True
    Dim sBOMView = sBom.BOMViews.Item("Только детали")
    For Each sRow As BOMRow In sBOMView.BOMRows
        Try
            Dim sCompDef = sRow.ComponentDefinitions.Item(1)
            If sCompDef.Type = ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then
                Try
                    If sCompDef.HasFlatPattern Then
                        Dim oFlat = sCompDef.FlatPattern
                        Dim oStr = sCompDef.Document.DisplayName
                        oStr = oStr + ";" + (oFlat.Length * 10).ToString
                        oStr = oStr + ";" + (oFlat.Width * 10).ToString
                        oStr = oStr + ";" + (sCompDef.Thickness.Value * 10).ToString
                        oStr = oStr + ";" + (sCompDef.Material.Name).ToString
                        oStr = oStr + ";" + (sRow.ItemQuantity).ToString
                        System.IO.File.AppendAllText(ThisDoc.PathAndFileName(False) + extension, oStr + vbNewLine, System.Text.Encoding.Default)
                    End If
                Catch
                    MessageBox.Show("Ошибка 2", "Ошибка")
                End Try
            End If
        Catch
            MessageBox.Show("Ошибка 3", "Ошибка")
        End Try
    Next
Catch
    MessageBox.Show("Ошибка 4", "Ошибка")
End Try
Try
    ThisDoc.Launch(ThisDoc.PathAndFileName(False) + extension)
Catch
    MessageBox.Show("Ошибка открытия файла", "Ошибка")
End Try
Jelte de Jong
Blog: hjalte.nl - github.com
