09-21-2023
05:02 AM
- Mute
- Permalink
- Report
09-21-2023
05:02 AM
try this
Sub Main()
Dim oAsm As DrawingDocument = Invapp.ActiveDocument
MsgBox(oAsm.FullDocumentName)
SetParameterValue(oAsm, "test", 15)
End Sub
Public Sub SetParameterValue(Doc As drawingDocument, ParameterName As String, Val As Object)
Dim oPS As Parameters = Doc.Parameters
Dim oP As Parameter
Try
oP = oPS.Item(ParameterName)
Catch
'Parameter Does Not Exist
Exit Sub
End Try
oP.Value = Val
End Sub
Sub Main()
End Sub
Dim oP As Parameter
Try
Catch
Exit Sub
End Try
oP.Value = Val
End Sub
Arthur Knoors
Autodesk Affiliations:
