anavazquez5LRNJ
in reply to: A.Acheson
Hi @A.Acheson ,I no longer see errors as such but I have some problems with the rule, for example the rule does not always work, if the cursor is not positioned on the sheet or if you touch the view with the cursor or simply stops working and no longer lets you select the component, I do not know if this is because of the class that selects the components or is something wrong declared, because I need to let me choose any part of the sheet so that there is placed the dimension of the occurrence.
