Hunter_SimpsonKGQW5
413 Views, 1 Reply
Model States & iLogic
I am working with an assembly model that is driven via iLogic Forms.
There are 120 possible configurations.
What is the best way to save all model states such that the iLogic drives the changes automatically when swapping between models states without having to manually use the form to update the changes.
I need to have create drawings that represents each configuration and represents each configuration in it's state.
Currently, when I swap between model states I have to open the Forms to run the iLogic to configure.
Add your iLogic into the Model State trigger for Model State Activation:
