09-14-2023
05:52 AM
- Mute
- Permalink
- Report
09-14-2023
05:52 AM
Rule to publish the DXF from main assembly with description and part number
Hi All ,
the below rule is generating step files through main assembly is there way to modify it to generate DXF for sheet metal parts, thanks.
'check that the active document is an assembly file If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then MessageBox.Show("This Rule " & iLogicVb.RuleName & " only works on Assembly Files.", "WRONG DOCUMENT TYPE", MessageBoxButtons.OK, MessageBoxIcon.Error) Return End If 'define the active document as an assembly file Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument Dim oAsmName As String = ThisDoc.FileName(False) 'without extension 'get user input Dim RUsure = MessageBox.Show( "This will create a STEP file for all components." _ & vbLf & " " _ & vbLf & "Are you sure you want to create STEP Drawings for all of the assembly components?" _ & vbLf & "This could take a while.", "iLogic - Batch Output STEPs ", MessageBoxButtons.YesNo) If RUsure = vbNo Then Return Else End If '- - - - - - - - - - - - -STEP setup - - - - - - - - - - - - Dim oPath = ThisDoc.Path 'get STEP target folder path ' original => oFolder = oPath & "\" & oAsmName & " STEP Files" Dim oFolder = oPath & "\STEP Files" 'Check for the step folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If '- - - - - - - - - - - - -Assembly - - - - - - - - - - - - ThisDoc.Document.SaveAs(oFolder & "\" & oAsmName & (".stp"), True) '- - - - - - - - - - - - -Components - - - - - - - - - - - - 'look at the files referenced by the assembly Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments 'work the referenced models For Each oRefDoc As Document In oRefDocs Dim oCurFile As Document = ThisApplication.Documents.Open(oRefDoc.FullFileName, True) Dim oCurFileName = oCurFile.FullFileName Dim ShortName = IO.Path.GetFileNameWithoutExtension(oCurFileName) Dim oPropSets As PropertySets = oCurFile.PropertySets Dim oPropSet As PropertySet = oPropSets.Item("Design Tracking Properties") Dim oDescriptionValue As [Property] = oPropSet.Item("Description") Try oCurFile.SaveAs(oFolder & "\" & oDescriptionValue.Value & (".stp"), True) Catch MessageBox.Show("Error processing " & oCurFileName, "ilogic") End Try oCurFile.Close() Next '- - - - - - - - - - - - - MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
