09-14-2023
04:42 AM
- Mute
- Permalink
- Report
09-14-2023
04:42 AM
Amazing. Thank you, that just works excelent. I wouldn't be able to write that code. I have just added an input box to the code and it is awesome.
Thank you
Sub Main If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then MsgBox("A Drawing document must be active for this code to work. Exiting.", vbCritical, "") Exit Sub End If Dim oDDoc As DrawingDocument = ThisDoc.Document Dim oSheets As Inventor.Sheets = oDDoc.Sheets 'get user input Dim sTextToFind As String = InputBox("Enter Text To Find:", "iLogic", "XXX") 'look for blank value If sTextToFind = "" Then Return 'exit rule End If Dim sTextToReplaceIt As String = InputBox("Enter Text To Replace '" & oTXT2Find _ & "' with.", "iLogic", "ZZZ") 'look for blank value If sTextToReplaceIt = "" Then Return 'exit rule End If For Each oSheet As Inventor.Sheet In oSheets Dim oCTables As Inventor.CustomTables = oSheet.CustomTables If oCTables.Count = 0 Then Continue For 'skip to next oSheet in loop For Each oCTable As Inventor.CustomTable In oCTables If oCTable.Title.Contains(sTextToFind) Then Try oCTable.Title = oCTable.Title.Replace(sTextToFind, sTextToReplaceIt) Catch Logger.Error("Error replacing text in Title of CustomTable") End Try End If '<<< you can traverse the data in the table by rows or by columns >>> Dim oRows As Inventor.Rows = oCTable.Rows For Each oRow As Inventor.Row In oRows For Each oCell As Inventor.Cell In oRow If oCell.Value.Contains(sTextToFind) Then Try oCell.Value = oCell.Value.Replace(sTextToFind, sTextToReplaceIt) Catch Logger.Error("Error replacing text in Cell of CustomTable") End Try End If Next 'oCell Next 'oRow Next 'oCTable Next 'oSheet If oDDoc.RequiresUpdate Then oDDoc.Update2(True) 'If oDDoc.Dirty Then oDDoc.Save2(False) End Sub
