09-14-2023
04:29 AM
- Mute
- Permalink
- Report
09-14-2023
04:29 AM
Hi @martin.jerabekM5BZE. Here is an iLogic rule example for finding & replacing text within either the Title, or the Cells of a CustomTable in a DrawingDocument. It is currently set up to loop through each sheet, and each CustomTable it finds on each sheet. Then after checking/processing its title, it will loop through each Row, and each Cell in each Row, checking/processing them.
Sub Main
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("A Drawing document must be active for this code to work. Exiting.", vbCritical, "")
Exit Sub
End If
Dim oDDoc As DrawingDocument = ThisDoc.Document
Dim oSheets As Inventor.Sheets = oDDoc.Sheets
Dim sTextToFind As String = "ToFind"
Dim sTextToReplaceIt As String = "Replacement"
For Each oSheet As Inventor.Sheet In oSheets
Dim oCTables As Inventor.CustomTables = oSheet.CustomTables
If oCTables.Count = 0 Then Continue For 'skip to next oSheet in loop
For Each oCTable As Inventor.CustomTable In oCTables
If oCTable.Title.Contains(sTextToFind) Then
Try
oCTable.Title = oCTable.Title.Replace(sTextToFind, sTextToReplaceIt)
Catch
Logger.Error("Error replacing text in Title of CustomTable")
End Try
End If
'<<< you can traverse the data in the table by rows or by columns >>>
Dim oRows As Inventor.Rows = oCTable.Rows
For Each oRow As Inventor.Row In oRows
For Each oCell As Inventor.Cell In oRow
If oCell.Value.Contains(sTextToFind) Then
Try
oCell.Value = oCell.Value.Replace(sTextToFind, sTextToReplaceIt)
Catch
Logger.Error("Error replacing text in Cell of CustomTable")
End Try
End If
Next 'oCell
Next 'oRow
Next 'oCTable
Next 'oSheet
If oDDoc.RequiresUpdate Then oDDoc.Update2(True)
'If oDDoc.Dirty Then oDDoc.Save2(False)
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS)
Wesley Crihfield
(Not an Autodesk Employee)
