wylieDWRUN
421 Views, 2 Replies
Ilogic; unfold sheet metal part based on named entity face.
Hi all,
I am using a code that I found online that runs from an assembly and DXFs all sheet metal parts however It doesn't consider if the part has a finish side or not so I am encountering the issue where I have to manually set the base face for parts that have a finished side. I would like to use the name entity feature to name the finished faces "Good Side" and unfold the models using the "Good Side" as the base face if the part has a matching named entity.
I am open to using something other than the name entity feature to name the face.
