A.Acheson
in reply to: CGVJM6DF
Hi @CGVJM6DF
Can you attach the code you have worked on as it might just need some review. Where did you have trouble in making it work?
Can you explain currently how you are doing this process manually? Can you share the screenshots of the process?
If you only want to target the subassembly parts then you can open the subassembly exclusively and export the bom from there.
Regards
Alan
