anavazquez5LRNJ
479 Views, 8 Replies
Selecting occurrences of an assembly in a drawing
Hi, I have been working on creating automated dimensions but I would like to create dimensions every time you click on any part of the subassembly that needs to be dimensioned, but in order to do so I need to have the name of the subassembly and from there get the workplane, here my question I have found this code in the forum but I can not get the name of the subassembly but I get the occurrences that are within it, is it possible to get the name of the subassembly as such?
Sub Main
    Dim oSelect As New clsSelect
    oSelect.SelectOccurrence(ThisApplication)
    Dim oOcc As ComponentOccurrence = oSelect.SelectedOcc
    oSelect = Nothing
    Dim docName As String = oOcc.Definition.Document.FullFileName
    MessageBox.Show(oOcc.Name )
End Sub
Class clsSelect
    Private WithEvents oInteractEvents As InteractionEvents
    Private WithEvents oSelectEvents As SelectEvents
    Private bTooltipEnabled As Boolean
    Private ThisApplication As Inventor.Application
    Public SelectedOcc As ComponentOccurrence
    Private stillSelecting As Boolean = True
    Public Sub SelectOccurrence(oApp As Inventor.Application)
        ThisApplication = oApp
        oInteractEvents = ThisApplication.CommandManager.CreateInteractionEvents
        oInteractEvents.InteractionDisabled = False
        oSelectEvents = oInteractEvents.SelectEvents
        oSelectEvents.AddSelectionFilter(SelectionFilterEnum.kDrawingCurveSegmentFilter)
        oSelectEvents.WindowSelectEnabled = False
        bTooltipEnabled = ThisApplication.GeneralOptions.ShowCommandPromptTooltips
        ThisApplication.GeneralOptions.ShowCommandPromptTooltips = True
        oInteractEvents.StatusBarText = "Select component"
        oInteractEvents.Start()
        While stillSelecting
            ThisApplication.UserInterfaceManager.DoEvents()
        End While
    End Sub
    Private Sub oInteractEvents_OnTerminate() Handles oInteractEvents.OnTerminate
        ThisApplication.GeneralOptions.ShowCommandPromptTooltips = bTooltipEnabled
        oSelectEvents = Nothing
        oInteractEvents = Nothing
        stillSelecting = False
    End Sub
    Private Sub oSelectEvents_OnPreselect(ByRef PreSelectEntity As Object, ByRef DoHighlight As Boolean, ByRef MorePreSelectEntities As ObjectCollection, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Inventor.Point2d, ByVal View As Inventor.View) Handles oSelectEvents.OnPreselect
        Try
            Dim oCurves As DrawingCurvesEnumerator = DirectCast(PreSelectEntity, DrawingCurveSegment).Parent.Parent.DrawingCurves(DirectCast(PreSelectEntity, DrawingCurveSegment).Parent.ModelGeometry.Parent.Parent)
            Dim oCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
            For Each oCurve As DrawingCurve In oCurves
                For Each oSeg As DrawingCurveSegment In oCurve.Segments
                    If oSeg IsNot PreSelectEntity Then oCol.Add(oSeg)
                Next
            Next
            MorePreSelectEntities = oCol
            DoHighlight = True
        Catch
            DoHighlight = False
        End Try
    End Sub
    Private Sub oSelectEvents_OnSelect(ByVal EntireSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As Inventor.View) Handles oSelectEvents.OnSelect
        SelectedOcc = DirectCast(EntireSelectedEntities.Item(1), DrawingCurveSegment).Parent.ModelGeometry.Parent.Parent
        ThisApplication.CommandManager.StopActiveCommand
    End Sub
End Class
