09-08-2023
11:29 AM
- Mute
- Permalink
- Report
09-08-2023
11:29 AM
Here is an example of using Lists to collect information:
Sub Main
Dim dDoc As DrawingDocument = TryCast(ThisApplication.ActiveDocument, DrawingDocument)
If IsNothing(dDoc) Then Logger.Debug("Not Run In Drawing Document") : Exit Sub
Dim PickView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a View to collection points")
If IsNothing(PickView) Then Exit Sub ' If nothing gets selected then we're done
Dim CoordinateList As New List(Of List(Of Double))
For Each dc As DrawingCurve In PickView.DrawingCurves
If IsNothing(dc.MidPoint) Then Continue For 'Skip
Dim MidPointList As New List(Of Double)
MidPointList.AddRange({dc.MidPoint.X, dc.MidPoint.Y}) 'Add for 3D points: , dc.CenterPoint.Z})
CoordinateList.Add(MidPointList)
Next
For Each CollectedList As List(Of Double) In CoordinateList
Dim MessageString As String = Nothing
If CollectedList.Count = 3
MessageString = "X: " & CollectedList.Item(0) & " | Y: " & CollectedList.Item(1) & " | Z: " & CollectedList.Item(2)' 3D Points
Else If CollectedList.Count = 2
MessageString = "X: " & CollectedList.Item(0) & " | Y: " & CollectedList.Item(1)' 2D Points
End If
Logger.Trace(MessageString)
Next
End Sub
It is not the only way to collect information, but it might help you understand value collections. If you want the objects themselves, you can use an ObjectCollection:
Sub Main
Dim DrawingCurveCollection As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
DrawingCurveCollection.Add(dc)
Next
Dim testingLimiter As Integer = 15 'Testing purposes only to limit messageboxes if user selects a view with many drawing curves
Dim TextCounter As Integer = 0 'Testing purposes only to limit messageboxes if user selects a view with many drawing curves
Dim selectThis As HighlightSet = ThisApplication.ActiveDocument.CreateHighlightSet
For Each CollectedDrawingCurve As DrawingCurve In DrawingCurveCollection
TextCounter += 1
If TextCounter > testingLimiter Then Exit For
selectThis.AddItem(CollectedDrawingCurve.Segments(1))
MessageBox.Show("Highlighted First Segment of a DrawingCurve")
selectThis.Clear
Next
End Sub
