- Mute
- Permalink
- Report
Exporting Content Center Data (Part Number, Description, etc.) to an Excel file
Hello, I would like to export data from a custom content center library to an excel file so that I can share it with our purchasing/inventory teams.
Basically, I would like to compile an excel sheet with data (Part Number, Vendor, Stock Number, and Description) from all the parts in a custom content center we have created. I found a decent article on the Autodesk website with an iLogic code which I believe is getting me on the right track, but I am having issues modifying the code to pull all of the previously mentioned data, specifically Vendor and Description.
Here is a link to the code:
How to export the whole Inventor Content Center Library Standard to the Excel file.
- Mute
- Permalink
- Report
Edit custom content center.
Edit the table in Excel and copy or save it as another file.
- Mute
- Permalink
- Report
The iLogic code I linked initially gets close but doesn't include all of the data that I need.
- Mute
- Permalink
- Report
Adjusting this type of code really is a trial and error approach. Your families need to have consistent internal names. I suggest to carefully follow the patterns for each iproperty. Can you post the modified code your using?
Or if this helped you, please, click (like)
Regards
Alan
- Mute
- Permalink
- Report
I just took the code linked in the original post and added Vendor, Stock Number, and Description following the patterns I could find. It worked for Stock Number, but for some reason Vendor and Description are not populating.
I also noticed that the results of running the code differ each time I run it (ie. the first time it had data populated for ~1400 parts, the second time ~600 parts, and the third time ~1800 parts).
- Mute
- Permalink
- Report
It seemed to work ok for me. For the iproperties not working is the internal column name matching? The display name and internal name might be different.
Regards
Alan
