Hi @kresh.bell ,
I started replying to this earlier but had to take a meeting, and @Andrii_Humeniuk was too fast for me! and had already provided a solution by the time I started to post this.
In any case, I had this version ready, so I'll share it also... maybe it'll help someone in the future.
It looks like the 2 versions work pretty much the same.
The primary difference I see is that Andrii's excellent version reaches down into a subassembly and gets the part, when a subassembly is selected. Whereas my example gets the subassembly description.
Also my example highlights the selected component by using the select set and puts the name in the message box, but those are minor differences.
I hope this helps.
Curtis
Dim oOccurrence As ComponentOccurrence
msg = "Select a component (press ESC to exit)"
While True
	oOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, msg)
	' If nothing gets selected then we're done
	If IsNothing(oOccurrence) Then Exit While
	oName = oOccurrence.Name
	ThisApplication.ActiveDocument.selectset.select(oOccurrence)
	oDesc = iProperties.Value(oName, "Project", "Description")
	oDesc = InputBox(oName & " Description", "iLogic", oDesc)
	If Not oDesc = Nothing Then iProperties.Value(oName, "Project", "Description") = oDesc
End While
