kresh.bell
465 Views, 8 Replies
Description iLogic
is it possible create rule for assembly environment for running small description window?
When I run rule I need select part, when I select part, I can add description for this part. If I select some other part, I can again add description for this selected part. When I finish with adding description, click esc or done for exit.
