Mac_W
400 Views, 3 Replies
Projected Arbitrary ISO DrawingView identifier
I have been working on a project where I need to be able to identify isometric views automatically. The drawings we use mostly have views that have been projected off a base view and when I try to identify views' camera.ViewOrientationType, most of them return back as arbitrary. I have figured out a way to discern iso views from the other views using my rule below.
The issue with this rule is that it currently only handles 4 views, I would like it to be able to handle however many views are on a sheet. I think if I used arrays or object collections this code could be a lot shorter and more powerful but I am having trouble figuring out how to do so. Any help and or advice for improving this rule would be greatly appreciated.
Sub Main()
	'run on IDW containing views of a rectangular profile part to delete any iso views
	Start:
	Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim oSheet As Sheet = oDoc.ActiveSheet
	Dim oViews As DrawingViews = oSheet.DrawingViews
	Dim oIntersectionIntent1 As GeometryIntent
	Dim oIntersectionIntent2 As GeometryIntent
	Dim oIntersectionIntent3 As GeometryIntent
	Dim oIntersectionIntent4 As GeometryIntent
	Dim intentPointOnSheet1 As Point2d
	Dim intentPointOnSheet2 As Point2d
	Dim intentPointOnSheet3 As Point2d
	Dim intentPointOnSheet4 As Point2d
	Dim intersectionPoint1 As Point2d
	Dim intersectionPoint2 As Point2d
	Dim intersectionPoint3 As Point2d
	Dim intersectionPoint4 As Point2d
	Dim minX1 As Double = oSheet.Width
	Dim minX2 As Double = oSheet.Width
	Dim minX3 As Double = oSheet.Width
	Dim minX4 As Double = oSheet.Width
	Dim maxX1 As Double = 0
	Dim maxX2 As Double = 0
	Dim maxX3 As Double = 0
	Dim maxX4 As Double = 0
	Dim minY1 As Double = oSheet.Height
	Dim minY2 As Double = oSheet.Height
	Dim minY3 As Double = oSheet.Height
	Dim minY4 As Double = oSheet.Height
	Dim maxY1 As Double = 0
	Dim maxY2 As Double = 0
	Dim maxY3 As Double = 0
	Dim maxY4 As Double = 0
	Dim i As Integer = 1 'represents DrawingView iteration
    For Each oView As DrawingView In oViews
        'Iterate through every drawing curve in the view
        For Each oCurve As DrawingCurve In oView.DrawingCurves()
			If i = 1 Then
				'Check if curve is a Line
	            If oCurve.ProjectedCurveType = Curve2dTypeEnum.kLineSegmentCurve2d Then
					'get midpoint location of line on sheet
	                oIntersectionIntent1 = oSheet.CreateGeometryIntent(oCurve, PointIntentEnum.kMidPointIntent)
	                intentPointOnSheet1 = oIntersectionIntent1.PointOnSheet
					'gets and sets if point is max/min X/Y for view on sheet
	                If intentPointOnSheet1.X > maxX1 Then
	                    maxX1 = intentPointOnSheet1.X
	                    maxLineSegmentX1 = oCurve.Segments(1).Geometry
	                End If
	                If intentPointOnSheet1.X < minX1 Then
	                    minX1 = intentPointOnSheet1.X
	                    minLineSegmentX1 = oCurve.Segments(1).Geometry
	                End If
	                If intentPointOnSheet1.Y > maxY1 Then
	                    maxY1 = intentPointOnSheet1.Y
	                    maxLineSegmentY1 = oCurve.Segments(1).Geometry
	                End If
	                If intentPointOnSheet1.Y < minY1 Then
	                    minY1 = intentPointOnSheet1.Y
	                    minLineSegmentY1 = oCurve.Segments(1).Geometry
	                End If
	            End If
			Else If i = 2 Then
	                oIntersectionIntent2 = oSheet.CreateGeometryIntent(oCurve, PointIntentEnum.kMidPointIntent)
	                intentPointOnSheet2 = oIntersectionIntent2.PointOnSheet
	                If intentPointOnSheet2.X > maxX2 Then
	                    maxX2 = intentPointOnSheet2.X
	                    maxLineSegmentX2 = oCurve.Segments(1).Geometry
	                End If
	                If intentPointOnSheet2.X < minX2 Then
	                    minX2 = intentPointOnSheet2.X
	                    minLineSegmentX2 = oCurve.Segments(1).Geometry
	                End If
	                If intentPointOnSheet2.Y > maxY2 Then
	                    maxY2 = intentPointOnSheet2.Y
	                    maxLineSegmentY2 = oCurve.Segments(1).Geometry
	                End If
	                If intentPointOnSheet2.Y < minY2 Then
	                    minY2 = intentPointOnSheet2.Y
	                    minLineSegmentY2 = oCurve.Segments(1).Geometry
	                End If
	            End If
			Else If i = 3 Then
	                oIntersectionIntent3 = oSheet.CreateGeometryIntent(oCurve, PointIntentEnum.kMidPointIntent)
	                intentPointOnSheet3 = oIntersectionIntent3.PointOnSheet
	                If intentPointOnSheet3.X > maxX3 Then
	                    maxX3 = intentPointOnSheet3.X
	                    maxLineSegmentX3 = oCurve.Segments(1).Geometry
	                End If
	                If intentPointOnSheet3.X < minX3 Then
	                    minX3 = intentPointOnSheet3.X
	                    minLineSegmentX3 = oCurve.Segments(1).Geometry
	                End If
	                If intentPointOnSheet3.Y > maxY3 Then
	                    maxY3 = intentPointOnSheet3.Y
	                    maxLineSegmentY3 = oCurve.Segments(1).Geometry
	                End If
	                If intentPointOnSheet3.Y < minY3 Then
	                    minY3 = intentPointOnSheet3.Y
	                    minLineSegmentY3 = oCurve.Segments(1).Geometry
	                End If
	            End If
			Else If i = 4 Then
	                oIntersectionIntent4 = oSheet.CreateGeometryIntent(oCurve, PointIntentEnum.kMidPointIntent)
	                intentPointOnSheet4 = oIntersectionIntent4.PointOnSheet
	                If intentPointOnSheet4.X > maxX4 Then
	                    maxX4 = intentPointOnSheet4.X
	                    maxLineSegmentX4 = oCurve.Segments(1).Geometry
	                End If
	                If intentPointOnSheet4.X < minX4 Then
	                    minX4 = intentPointOnSheet4.X
	                    minLineSegmentX4 = oCurve.Segments(1).Geometry
	                End If
	                If intentPointOnSheet4.Y > maxY4 Then
	                    maxY4 = intentPointOnSheet4.Y
	                    maxLineSegmentY4 = oCurve.Segments(1).Geometry
	                End If
	                If intentPointOnSheet4.Y < minY4 Then
	                    minY4 = intentPointOnSheet4.Y
	                    minLineSegmentY4 = oCurve.Segments(1).Geometry
	                End If
	            End If
			End If
        Next
		If i = 1 Then
			'create minX/Y lines to find intersection
	        Dim lineX1 = ThisApplication.TransientGeometry.CreateLine2d(minLineSegmentX1.StartPoint, minLineSegmentX1.Direction)
			Dim lineY1 = ThisApplication.TransientGeometry.CreateLine2d(minLineSegmentY1.StartPoint, minLineSegmentY1.Direction)
			'get intersection point of minX/Y lines
	        intersectionPoint1 = lineX1.IntersectWithCurve(lineY1)(1)
			'if intersection point is inline with minX/Y midpoints then view is not iso
			If intersectionPoint1.X = minX1 And intersectionPoint1.Y = minY1 Then
				MsgBox(oView.Name & " NOT iso")
				MsgBox("minX1: " & minX1 & " intersectionPoint1.X: " & intersectionPoint1.X & " minY1: " & minY1 & " intersectionPoint1.Y: " & intersectionPoint1.Y)
			Else
				MsgBox(oView.Name & " IS iso")
				Try
					oView.Delete
					GoTo Start
				Catch
					MsgBox("View deletion failed")
				End Try
			End If
		Else If i = 2 Then
			Dim lineX2 = ThisApplication.TransientGeometry.CreateLine2d(minLineSegmentX2.StartPoint, minLineSegmentX2.Direction)
	        Dim lineY2 = ThisApplication.TransientGeometry.CreateLine2d(minLineSegmentY2.StartPoint, minLineSegmentY2.Direction)
	        intersectionPoint2 = lineX2.IntersectWithCurve(lineY2)(1)
			If intersectionPoint2.X = minX2 And intersectionPoint2.Y = minY2 Then
				MsgBox("minX2: " & minX2 & " intersectionPoint2.X: " & intersectionPoint2.X & " minY2: " & minY2 & " intersectionPoint2.Y: " & intersectionPoint2.Y)
			Else
				Try
					oView.Delete
					GoTo Start
				Catch
				End Try
			End If
		Else If i = 3 Then
			Dim lineX3 = ThisApplication.TransientGeometry.CreateLine2d(minLineSegmentX3.StartPoint, minLineSegmentX3.Direction)
	        Dim lineY3 = ThisApplication.TransientGeometry.CreateLine2d(minLineSegmentY3.StartPoint, minLineSegmentY3.Direction)
	        intersectionPoint3 = lineX3.IntersectWithCurve(lineY3)(1)
			If intersectionPoint3.X = minX3 And intersectionPoint3.Y = minY3 Then
				MsgBox("minX3: " & minX3 & " intersectionPoint3.X: " & intersectionPoint3.X & " minY3: " & minY3 & " intersectionPoint3.Y: " & intersectionPoint3.Y)
			Else
				Try
					oView.Delete
					GoTo Start
				Catch
				End Try
			End If
		Else If i = 4 Then
			Dim lineX4 = ThisApplication.TransientGeometry.CreateLine2d(minLineSegmentX4.StartPoint, minLineSegmentX4.Direction)
	        Dim lineY4 = ThisApplication.TransientGeometry.CreateLine2d(minLineSegmentY4.StartPoint, minLineSegmentY4.Direction)
	        intersectionPoint4 = lineX4.IntersectWithCurve(lineY4)(1)
			If intersectionPoint4.X = minX4 And intersectionPoint4.Y = minY4 Then
				MsgBox("minX4: " & minX4 & " intersectionPoint4.X: " & intersectionPoint4.X & " minY4: " & minY4 & " intersectionPoint4.Y: " & intersectionPoint4.Y)
			Else
				Try
					oView.Delete
					GoTo Start
				Catch
				End Try
			End If
		End If
		i = i + 1
    Next
End Sub
