JohnBoySarcia
in reply to: WCrihfield
Thank you for your response, the link shows mostly on appearance as an example and need to pick occurrences prior to change. Would it be possible to have an ilogic code from Autodesk inventor 2022 version to have all material within assembly will be change based on selection? my parameter Material has selection. Also, on those examples the set command doesn't exist on my current version. Thanks
