ralfmja
in reply to: Michael.Navara
Hi @Michael.Navara ,
Thank you very much for your interest :slightly_smiling_face:
In short, I'm an amateur :winking_face:
I'm looking for existing rules, I'm changing them for my ideas due to the fact that I have no experience in programming :slightly_smiling_face:
However, I have a lot of experience in designing and I know what I want to achieve :slightly_smiling_face:
Coming back to your proposal, the effect is in line with my assumptions. However, I need an "action" that will be copied to the solid in which I want to create holes "surfaces" (so that I can enable/disable its adaptivity). Then from this "copied surface" I want to create a sketch and in it (possibly) measure the diameters of the projected circles and insert the appropriate holes :slightly_smiling_face:
Why so?? because (in my opinion) the standard adaptability in inventor causes more problems than good in large assemblies :slightly_smiling_face:
recreating this scheme in the "normal" Inventor operation, I would like to do it as in the video below (of course, I only need to copy surfaces with holes, not the entire solid):
To sum up - I want to copy surfaces (one or several which will be adaptive) and create a sketch in a part from it, and then create holes based on this sketch.
Can you help me achieve this?? :slightly_smiling_face:
