09-05-2023
08:09 AM
- Mute
- Permalink
- Report
09-05-2023
08:09 AM
This is not an answer but topic to discuss.
I don't understand why you create some non-parametric base features if you want to create planar sketch. You can create sketch directly on part planar face.
Here is more compact sample how to do it. You can select multiple source faces for hole placement.
Sub Main()
Dim asm As AssemblyDocument = ThisDoc.Document
Dim targetFaceProxy As FaceProxy = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Pick target face or work plane")
Dim targetOccurrence As ComponentOccurrence = targetFaceProxy.ContainingOccurrence
Dim targetTransformation As Matrix = targetOccurrence.Transformation
targetTransformation.Invert()
Dim targetPartDef As PartComponentDefinition = targetOccurrence.Definition
Dim targetFace As Face = targetFaceProxy.NativeObject
Dim holeCenters As New List(Of Point)
Do
Dim sourceFace As FaceProxy = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Pick source face or press ESC to continue")
If sourceFace Is Nothing Then Exit Do
Dim sourceOccurrence As ComponentOccurrence = sourceFace.ContainingOccurrence
Dim sourcePartDef As PartComponentDefinition = sourceOccurrence.Definition
For Each edgeLoop As EdgeLoopProxy In sourceFace.EdgeLoops
If edgeLoop.IsOuterEdgeLoop Then Continue For
Dim tempWorkPoint As WorkPoint = sourcePartDef.WorkPoints.AddAtCentroid(edgeLoop.NativeObject, True)
Dim holeCenterPoint As Point = tempWorkPoint.Point
tempWorkPoint.Delete()
holeCenterPoint.TransformBy(sourceOccurrence.Transformation)
holeCenterPoint.TransformBy(targetTransformation)
holeCenters.Add(holeCenterPoint)
Next
Loop While True
'Create sketch with center points
Dim sketch As PlanarSketch = targetPartDef.Sketches.Add(targetFace)
For Each holeCenter As Point In holeCenters
Dim holeCenter2d = sketch.ModelToSketchSpace(holeCenter)
sketch.SketchPoints.Add(holeCenter2d, True)
Next
End Sub
