I need urgently the code for Inventor 2021 - I get here constantly the error message " Error Invalid Path" - can someone help me?
AddReference "Microsoft.Office.Interop.Excel.dll"
Imports Microsoft.Office.Interop.Excel
Sub Main
'Specify the Excel file's (Workbook) full path & file name (with extension)
'It is calling a Windows OpenFileDialog to allow the user to do this
Dim oFileName As String = GetExcelFile()
'Specify the Sheet name within the workbook
'perhaps this name could be selected from a list of all available sheets
'in the Excel Workbook once opened, of you don't want to manually specify it here?
Dim oSheetName As String = "Sheet1"
'Start a new instance of the Excel application
Dim oExcelApp As Microsoft.Office.Interop.Excel.Application
oExcelApp = New Microsoft.Office.Interop.Excel.ApplicationClass
oExcelApp.DisplayAlerts = False
oExcelApp.Visible = False
'[ Attempt to open the specified Workbook (file) using the supplied file name
Dim oWB As Workbook
Try
	oWB = oExcelApp.Workbooks.Open(oFileName)
Catch oEx As Exception
	MsgBox("The attempt to open the Excel file named '" & oFileName & "' failed." & vbCrLf & _
	"The error message for this failure is as follows:" & vbCrLf & _
	oEx.Message & vbCrLf &  vbCrLf & _
	"Its 'StackTrace is as follows:" & vbCrLf & _
	oEx.StackTrace & vbCrLf & vbCrLf & _
	"Its source is as follows:" & vbCrLf & _
	oEx.Source, vbOKOnly + vbCritical, "Couldn't Open File")
	Exit Sub
End Try
'Attempt to get the Worksheet
Dim oWS As Worksheet
Try
	oWS = oWB.Sheets.Item(oSheetName)
Catch
	oWS = oWB.ActiveSheet
Catch
	oWS = oWB.Worksheets.Item(1)
Catch
	MsgBox("No Worksheet was found in the specified Excel file. Exiting.", vbOKOnly + vbCritical, " ")
	Exit Sub
End Try
Dim oCells As Range = oWS.Cells
'Define the active Assembly and all related variables
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Assembly Documents.",vbOKOnly, "WRONG DOCUMENT TYPE")
	Exit Sub
End If
Dim oADoc As AssemblyDocument = ThisAssembly.Document
Dim oDir As String = System.IO.Path.GetDirectoryName(oADoc.FullFileName)
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oOccs As ComponentOccurrences = oADef.Occurrences
Dim oOcc As ComponentOccurrence
Dim oPDoc As PartDocument
Dim oDProps As Inventor.PropertySet 'Design Tracking Properties (Project)
Dim oSProps As Inventor.PropertySet 'Inventor Summary Information (Summary)
Dim oMatrix As Inventor.Matrix = ThisApplication.TransientGeometry.CreateMatrix
'Find the last row and last column being used to limit our loop ranges
Dim oLastRow As Integer = oWS.UsedRange.Rows.Count
'Dim oLastCol As Integer = oWS.UsedRange.Columns.Count
'Dim oColumnHeadersRow As Integer = 1
Dim o1stDataRow As Integer = 2
Dim oRow, oQty As Integer
Dim oPName, oPNum, oVendor, oNotes As String
For oRow = o1stDataRow To oLastRow
	'First number is Row index, second number is Column Index
	oQty = oCells.Item(oRow, 1).Value
	oPName = oCells.Item(oRow, 2).Value
	oPNum = oCells.Item(oRow, 3).Value
	oVendor = oCells.Item(oRow, 4).Value
	oNotes = oCells.Item(oRow, 5).Value
	'Create the new Part
	oPDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, , False)
	'Set the iProperties within the new Part
	oDProps = oPDoc.PropertySets.Item("Design Tracking Properties")
	oSProps = oPDoc.PropertySets.Item("Inventor Summary Information")
	oDProps.Item("Description").Value = oPName
	oDProps.Item("Part Number").Value = oPNum
	oDProps.Item("Vendor").Value = oVendor
	oSProps.Item("Comments").Value = oNotes
	'<<<< !!! CHECK IF THIS IS OK BEFORE RUNNING !!! >>>>
	'Saving each new Part to the same directory as the Assembly
	'if this is not OK, you could specify a different directory
	'or you could use a SaveFileDialog for this
	'or just skip saving the parts at this stage altogether
	oPDoc.SaveAs(oDir & "\" & oPName & ".ipt", False)
	'Add that many of this part to the assembly
	For i = 1 To oQty
		oOccs.AddByComponentDefinition(oPDoc.ComponentDefinition, oMatrix)
	Next
Next
'Close the Workbook (file)
oWB.Close
'Close this instance of the Excel application
oExcelApp.Quit
End Sub
Function GetExcelFile() As String
	Dim oOpenDlg As New System.Windows.Forms.OpenFileDialog
	oOpenDlg.Title = "Browse To And Select Your Excel File."
	oOpenDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
	oOpenDlg.Filter = "Excel Files (*.xls;*.xlsx)|*.xls;*.xlsx"
	oOpenDlg.Multiselect = False
	oOpenDlg.RestoreDirectory = False
	Dim oResult = oOpenDlg.ShowDialog
	If oResult = vbOK Then
		If oOpenDlg.FileName <> vbNullString Then
			oFileName = oOpenDlg.FileName
		Else
			MsgBox("No file was selected. Exiting.", vbOKOnly + vbExclamation, "FILE NOT SELECTED")
		End If
	ElseIf oResult = vbCancel Then
		MsgBox("The dialog was Canceled. Exiting.", vbOKOnly + vbInformation, "CANCELED")
	End If
	GetExcelFile = oFileName
End Function
